New first time build parts compatibility.
Approximate Purchase Date: Next 2 weeks
Budget Range:$1000 $1100 maybe more or less.Good starting point.
System Usage from Most to Least Important:Gamming,Internet
Parts Not Required:**ketboard,mouse,speakers,sound card ram posobly
Preferred Website(s) for Parts: Newegg,microcenter other as long as there repulible
Country of Origin: Texas USA
Parts Preferences: )INTELL.Nividea,major brands or compitible
Overclocking: Yes
SLI or Crossfire: Maybe
Monitor Resolution: (e.g.: 1024x768, 1280x1024, 1440x900, 1600x1200,, My current monitor will only do 1600. Will get another monitor but after build
Additional Comments:Not for sure on what MB,and can I use the ram I have now.Case is the one part about building my own I am looking forward to.If the case I picked out is not a good case please explain.Please by all means advise on hardware and buils specs.
cpu>sandy bridge i5 2500k---microcenter pickup $179
MB>Need help choosing>want a fullATX MB nothing small lots of room
Memmory>Currently have,will it work.
http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=02E4341CA5CA7304
Video card>EVGA SuperClocked 012-P3-1572-AR GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130595
hard drive>samsung spinpoint F3 500GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181&cm_re=spinpoint_f3-_-22-152-181-_-Product
optical drive>ASUS Black 24X DVD+R 8X
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
case>NZXT Phantom PHAN-001WT White Steel / Plastic ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146067
HEATSINK>COOLER MASTER Hyper 212 Plus >>would like to water coolif budget allows
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
windows 7 64 OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754&cm_re=windows_7_64_ome-_-32-116-754-_-Product
Will need thermal paist,any cables or anything I missed.
2 answers Last reply
More about time build parts compatibility
  1. Forgot the PSU.
    Antec EarthWatts EA750 750W Continuous Power ATX12V version 2.3 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC "compatible with Core i7/Core i5" Power Supply
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371026
  2. These boards require DDR3 Dual Channel RAM. Also down below is a case with better airflow
    http://www.coolermaster.com/product.php?product_id=6606 <--- more info on that CM HAF 922
    http://www.madshrimps.be/articles/article/1000116/ASRock-P67-Extreme4-Motherboard-Review/0 <--- Fairly recent review of the ASRock P67 Extreme4 with some o/c tips and great screenies.
    http://www.hardwareheaven.com/reviews/1098/pg10/asrock-extreme4-p67-and-fatal1ty-professional-p67-vs-x58-with-core-i7-950-review-overclocking.html <--- Recent yet not so in depth review of that same board.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197 $99.98 FREE SHIPPING
    COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157217 $152.99
    ASRock P67 Extreme4 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231427 $49.99 FREE SHIPPING
    G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBXL
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.591429 Combo Price: $154.98
    SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207008 $129.99
    XFX Core Edition PRO850W (P1-850S-CAB9) 850W ATX12V v2.2 & ESP12V v2.91 SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
    http://www.amazon.com/gp/product/B002G1YPH0/ref=s9_simh_gw_p23_d1_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-4&pf_rd_r=1GWS1E8RPTKAT5477YT7&pf_rd_t=101&pf_rd_p=470939031&pf_rd_i=507846 $28.46 & this item ships for FREE with Super Saver Shipping
    Cooler Master RR-B10-212P-G1 Hyper 212 Plus 775/1156/1366/AMD/AM2/AM3 Universal Direct Contact Heat-Pipe 120mm Fan CPU Cooler
New Build Systems Product
