Evening all,
I recently built a new machine with the following specs:
CPU: Core i7 950 @3.07ghz http://ark.intel.com/Product.aspx?id=37150
GPU: Inno3d Geforce 580 GTX 1.5GB http://www.inno3d.com/products/graphic_card/gf500/gtx_580.html
RAM: Corsair Dominator TR3X6G1600C8D http://www.corsair.com/products/corei7/default.aspx
MOBO: Asus P6X58D-E http://www.asus.com/product.aspx?P_ID=gFBKfNyhppW9tDbB&templete=2
PSU: Corsair HX 1000W http://www.corsair.com/products/hx1000/default.aspx
* Fully updated windows 7 x64
* Nvidia 263.09 drivers
* 3dmark06: 22,348
After building the system, windows 7 x64 installed properly and the system seemed to be completely stable, until i began to have issues while gaming:
General: Choppy mouse movement with Razer Lachesis (updated to 1.94 firmware for win 7 x64) which was fine with my previous desktop.
Games in which the FPS was below the refresh rate of the screen (60) with vsync active would "lag", as if the game itself slowed down to compensate for the drop in framerate. This was most noticeable on Crysis, Warhead and Metro 2033.
Crysis: I know it isnt exactly clever to draw conclusions from the systems performance in crysis, but it happened to be one of the only games easily accessible to me while i was setting up the system.
As above, the game seemed to jerk around while turning (objects would jerk from side to side, it would feel like sections of the screen were "dragging" accross while turning with the mouse or strafing.
The game would randomly slow down in areas which would normally not constitute a framerate drop, yet it would dip drastically.
After a few minutes of play, green artifacts would fill the screen and the game would crash to desktop. This has however been commentedon by other 580 owners and seems to be an inherant driver or hardware issue :/
PRIME95: I ran Prime95 with the entire system at default settings. After 9 hours no errors were reported, the system was stable at 64 degrees max.
MEMTEST: I checked and confirmed that the memory is elected is definitely compatible with my motherboard.
I ran memtest with detault settings and 2 passes completed with 0 errors. At this point i noticed that my ram had been set to DDR3 1067 automatically as opposed to DDR3 1600, but displayed the correct timings as 8-8-8-24, and displayed QPI as 4.8GT/s.
After changing the ram manually to DDR3 1600 i attempted to change the DRAM Bus Voltage, but when i reached 1.65 (the stated amount for the memory) i was presented with a message stating "According to Intel CPU SPEC, DIMMs with voltage setting over 1.65v may damage the CPU permanently!!"... I decided to leave it on Auto, which would "Increase voltage if required". I ran Memtest with these settings which stated the correct speed of 1600, but increased my timings to 9-9-9-24, and QPI as 6.4GT/s. One pass completed with 0 errors.
I jumped back into the bios and manually set the CAS latency, RAS to CAS Delay and RAS Precharge to 8, but i could not find the final setting so left the rest on Auto. Memtest displayed the ram as DDR3 1600, timings as 8-8-8-24, and QPI as 6.4GT/s. One pass completed with 0 errors.
* As far as i am aware XMP was enabled for all of these settings etc.
GPU Testing: So far all i have done to stress test the GPU is to run 3dmark06 in 1920x1200, 8x aa 16x af. It coped just fine and scored over 17k.
My questions as a complete newbie are:
1) Can i operate my DDR3 1600 dominator ram at full spec (1600, 8-8-8-24, 1.65v) with my current CPU and mobo?
2) What sort of settings should i use my RAM with to ensure the best performance with my motherboard and CPU?
3) If not, should i downclock it (and to what settings)? or should i RMA and get another type of memory?
4) Should i leave the DRAM Bus Voltage on auto, or set it to 1.65v manually after having set the ram to DDR3 1600? And if i change it manually, will it actually damage my i7 950?
5) Given my poor experience gaming but solid prime95 and memtest results is it fair to asume that the GPU / GPU drivers are causing my issues?
6) Could anyone please recommend a method to stress test my GPU to see if it is stable?
Sorry for the wall of text; i have a limited amount of time to get this system up and runnig properly
Thank youf or your help, it's greatly appreciated!
Cheers
-Zal
Note: Please don't reply with "RMA GPU /thread"
Note 2: this message has also been posted under Motherboards and Memory, sorry for double posting but md esperate to get it sorted out
* 3dmark06: 22,348
Cheers
-Zal
