Cpu water cooling for overlcoking
ghnader hsmithot
Please reconfirm your computer hardware then get back to us.
And i dont think water cooling is something for a someone inexperience to handle.From your post i dont think you are experience.You can however prove me wrong but once your pipe gets damaged or you have badly taken care of your hardware you would lose hundreds of dollars.
dhicks19
720
the pre filled no hassle kits are a good solution to cpu cooling. Such as the Corsair hydro H70. I had my I7 @ 4ghz around 75-80 degrees until I bought this cooler which dropped it to under 50 on full load
shadstarn
208
well yeah i thoguht they did not need any maintanance ..
but are those good for full overclocking?
the corsair 50 and the other one i listed here?
is antec kühler h2o 620 as good as the corsair 50 or better? or the other one
These are indeed sealed "no maintenance" kits but that doesn't mean something can't go wrong.
Also, they aren't really any better than good air cooling, just more expensive. The only really good thing is that they won't interfere with RAM slots.
You will still have to pull the motherboard out, pull the back plate off the CPU socket, put the appropriate retention plates on the front and back of the board, then mount the cooler, then put it back in the case, its not that much easier to install, but it is close to double the price for a tiny bit better cooling.
shadstarn
208
i really never remember having to putt any xcalmps on the cpu ... wow.. my stock ones seem to be jujst putt right on ...
ou have a point there but i am faced with bigger questions right now
this is my current build : how long could my system last as a plausible gamimg machine if i replaced the processor with the 110t and overlocking .. or should i just wait 2 eyars and build a intel one.. because the intel 7 cpu is not much more expnesive then the 110 t here in norway.
AMD Phenom 9850 BlackEdt 2,5 Ghz BOXED
Socket AM2+ Quad-Core 4MB cache
1/4/2009
25418
OCZ DDR2 4096MB Gold GX XTC Dual Channel
PC2-6400 2x2048MB 800MHz. (5-5-5-18)
1/4/2009
26151
OCZ StealthXStream strømforsyning 600W
20/24pin ATX/BTX/PCI Express/SATA
1/4/2009
28877
Seagate Barracuda 7200.11 500 GB
7200RPM, 32MB, SATA2
1/4/2009
34355
Asus M3A79-T Deluxe, AMD 790FX+SB750
ATX, Socket-AM2+, DDR2, 4xPCI-Ex(2.0)x16
1/4/2009
29865
Netshop Miditower "Boreas"
Sort u/powersupply
1/4/2009
33508
ASUS Radeon HD6870 x 2 crossfire
9/24/2006
13902
shadstarn
208
wolfram your right but the fact is here the 955 is not much cheaper either from the 6 core monster.. its actually just 60 70 buks difference.. which makes it stpuid for me to go for the 955 specially also because i make music and do conversions which would benefit from the 6 core.. and the 6 core overlocked seem to be something even gamers like recently
500 is still too much for me as an upgrade.. i bet just momentarely atelst the upgrade to cpu would be enogh to get teh boost i need as of pr day . but i dont know if it will last atleast 1 year .
games are getting more effiecient thankfully but i don tknow
i already run crysis 2 on full and pretty good speed almost exactly no lag.. so i bet the cpu upgrade will take away any unnoticable lags too but i dont know if game developement for the next year will go in the same direction or not. i kinda hope i could run duke 4 ever fluently at this point
shadstarn
208
hey guys i did order the II 6 110 AND liquid cooler .. so i am going ot overlock it! hope it will change somethings
i now wonder why my pc cant find the second graphic card suddenly .. it only shows one card?
also inside device manager only one card?
how can i fix this?
i checked the hardware is connected like it was before when it did find it.
this happened after i installed msi afterburner
shadstarn
208
i got this now
and i will probably overclock it .. do i need to buy paste ? or does the paste come with these and which of the paste should i use .. if i have to buy paste what type of paste and brand do you recommend ?
Antec KÜHLER H2O 620 -
AMD Phenom II X6 1100T Black Edition - 3,3 GHz - Socket AM3 (HDEOOZFBGRBOX)
