Help, my first major build
Hey. I am going to build my first computer. Can you check all the parts for compatibility or any recommended changes thanks.
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=12324134
3 answers Last reply
More about help major build
  1. You need to change the RAM, you want dual, not triple channel memory
  2. And it looks like that mobo only supports DDR3 1333 or 1066, not 1600
    http://www.tomshardware.com/forum/261222-31-build-advice <----- :bounce:
Build Computer Compatibility Systems
