G
Guest
Guest
I'm running Windows 7 on a Sager NP2098 notebook and consistently run into disconnects. I know it's not a router issue because my roommate's connection is perfectly fine even when mine gets dropped. I've exhausted most of the advice given for people with a similar situation on different forums, but nothing seems to remedy the situation.
One interesting thing to note is that if I disconnect, it takes a long time (I never measured) to reconnect. Sometimes, it won't reconnect at all and I have to disable my wireless adapter and re enable it in order to successfully connect to my wireless. On most, if not all, occasions it is much faster just to disable/enable the adapter instead of waiting.
My adapter is an Intel WiFi Link 5100 AGN. It takes me less than a second to connect to my internet.
Please help with whatever advice any of you can give.
