Will this work with eyefinity?
Related ressources
- 3 Monitors won't won't work with Eyefinity , only two. - Forum
- 7970.. can't get Eyefinity to work on more than 2 monitors. Help ! - Forum
- USB to VGA Adapter work for Eyefinity ? - Forum
- Will this work for eyefinity ? - Forum
- Can't get 3rd monitor to work with Eyefinity - it has DisplayPort! - Forum
Related ressources:
- Forumhttp://www.tomshardware.com/forum/ [...] isplayport
- ForumEyefinity w/2 Monitors - How do I create two distinct work spaces?
- ForumEyefinity wont work right with Crossfire..
- ForumWill a 60Hz TV work with a 240Hz TV in Eyefinity ?
- ForumWhich displayport to vga adapter work for eyefinity ?
- ForumEyefinity Will this work ?
- ForumEyefinity wont work with 3 monitors
- ForumMy game is telling me I need to install Physx, but I have an AMD card?
- Forum460 on this mobo?
- ForumGetting a new tv, not quite sure what gpu to get with it
- ForumWhere to find this amd card
- ForumMajor problem with 4870 1GB....
- Forum[Solved] Ati 5770 or 6850 with Phenom II X2 560BE
- Forum[Solved] Will a sapphire hd6850 fit?
- Forum[Solved] Need to replace GTX295 with equiv perf card from cur. prods. options?
- More resources
a DVI-VGA is an active adapter so YES u do need an active adapter.
