PLEASE HELP! PC Wont start
Hello, i built a new pc the specs are
HAF X
Intel 2600k
Corsair HX-1000 Power Supply
CoolerMaster Hyper 212+ CPU Cooler
Samsung SH-B123A 12X Blu-ray DVD Combo Drive
Corsair CMX8GX3M2A1333C9 8GB (2x4GB) DDR3
EVGA GeForce GTX 580 $699.00
Hitachi Deskstar 7K3000 3TB 7200RPM
ASUS P8P67 EVO Motherboard
Now i've checked with the manual and the cpu is plugged properly, arrow in the bottom corner, but when i turn the power everything starts to work, all fans, GPU, optical drive, but the cpu fan turns red and the dmm check light turns red, and there is no output to monitor (it stays black and power doesnt even turn on and when i turn it on it says 'no signal') and there is power to the mouse but not to the keyboard so i cant go to bios.
Sorry for long post but im really confused with this, and would really like to know your oppinion
2 answers Last reply
More about please help wont start
  1. dont worry, found out a socket on the cpu was broken
  2. ^ Socket or Pin ? Good that you found out the issue, also take a look at this sticky, will be very helpful to clear boot issues,...
    http://www.tomshardware.com/forum/261145-31-perform-steps-posting-boot-video-problems
New Build Systems
