Hello,
It's been a while that I've been trying to find out what the problem is with my computer. Here is my full story and the description of the problem.
Initial build:
CPU: Core i7 950
MOBO: Gigabyte GA-X58A-UD3R rev 3
RAM: G.Skill Kit Extreme3 3 x 2 GB PC12800 CAS 7 PI Series
GC: EVGA GTX580 superclocked
CASE: Corsair Graphite 600T
PSU: Corsair AX - 850W
HEATSINK: Noctua NH-D14
SSD: OCZ Vertex 2 120 GB
HDD: Samsung Spinpoint F3 S-ATA - 1000 GB - 32 MB
OS: Windows 7 64bit pro
I didn't realise that the RAM kit had that huge heat spread and made them impossible to install them with the noctua NH-D14. I decided to install the computer with the stock heatsink and then send the ram back for exchange. I picked the OCZ DDR3 3 x 2 GB PC12800 Platinum Edition.
So I installed windows and had the computer running for 2 days with no problems. Once I received the new RAM kit, I installed them as well as the heatsink, with "Optimized default settings". Every thing worked fine that day, but the next day windows was booting much slower and I stared getting random BSOD, I didn't even had the time to read the reason before the computer restarted. I immediately thought it was the new RAM, I changed the default settings but those recommended by OCZ:
RAM voltage: 1.644
QPI voltage: 1.344
Timmings: 7-7-7-24
Frequancy: 1600
I ran memtest with no errors for 2 passes. But the BSOD continued (MEMORY_MANGAMENT, and PAGE_FAULT_NONPAGED_AREA). If I ran memtest right after the BSOD I got lots of errors, so I changed to settings for the gigabyte defaults, then memtest passed just fine and windows booted with no BSOD.
Then I turned the computer off and when I turned back on the next day I got the BSOD after some minutes of running windows. I had to change the settings (going from default to recommended settings back and forth) and the BSOD would stop. The same thing happens the next day.
Then I decided to try and switch the PSU off and on when I got the BSOD, and I stop having the BSOD for the day, without changing the BIOS settings.
I can't say what is the problem:
PSU? RAM? MOBO?
Please help!
Thanks in advance
Sorry for my English
Initial build:
CPU: Core i7 950
RAM voltage: 1.644
QPI voltage: 1.344
Timmings: 7-7-7-24
Frequancy: 1600
PSU? RAM? MOBO?
Please help!
Thanks in advance
