Will Corsair CMZ8GX3M2A1600C9 ram work on my motherboard?
Last response: in Memory
January 3, 2012 5:29:55 PM
Hello I am doing my first computer build, and I am not sure if Corsair CMZ8GX3M2A1600C9 ram will work on my ASUS P8H61-M Pro Motherboard.
Corsair CMZ8GX3M2A1600C9 specification-
ASUS P8H61-M Pro Motherboard Specification-
http://www.asus.com/Motherboards/Intel_Socket_1155/P8H6..." target="_blank">[/url
Any advice is appreciated :)
a c 347 } Memory
a c 207 Ĉ ASUS
a c 716 V Motherboard
January 3, 2012 5:33:58 PM
Welcome to Tom's Forum! :)
Work yes, work at DDR3-1600 frequency no.
a b } Memory
a b Ĉ ASUS
a c 207 V Motherboard
January 3, 2012 6:46:20 PM
Your MoBo supports DDR3 1333/1066, so getting DDR3-1600 would be a few wasted bucks.....
Before I go further....did you choose H61 or it was just the right price range ?Read about what the different chipsets mean to you here:
http://www.ukgamingcomputers.co.uk/difference-between-h...
Quote:
Whilst this is a great feature it is worth noting the integrated graphics are not much cop and only really suited to HD video playback and very basic gaming .....
The downside of a H67 chipset is it supports very limited overclocking even if an unlocked ‘K’ Series CPU (i5 2500K & i7 2600K) is installed. To the overclockers, this is a completely no go chipset, but for everyone building a sandy bridge system on a budget it makes a great choice.
So in that regard, if you move to P67 or Z68, the tall RAM would be a concern as the memory you picked if you are planning on OC'ing, will likely hit the 3rd party CPU cooler ya would use.
a c 347 } Memory
a c 207 Ĉ ASUS
January 3, 2012 6:48:10 PM
The F3-10666CL9D-8GBRL is the same as the Crucial and Corsair posted earlier; DDR3-1333 CAS 9.
Here's a chart:
