Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Power icon shows "unknown remaining" after new battery
Forum Laptops & Notebooks : General Laptops & Notebooks - Power icon shows "unknown remaining" after new battery
Archived from groups: comp.sys.laptops (More info?)
Hi,
I have a Fujitsu-Siemens Amilo D 8820 on which I replaced a worn-out
battery with a non-original one.
After this the power monitor always reports "unknown remaining" charge
with this new battery but, if I replace the original battery the gauge
works as expected, although for only about 10 minutes because it is
over 2 years old.
The new battery charges and discharges as expected, with about 2 hours
autonomy, lights the charging led and flashes the power led when close
to ending charge, all as expected, just doesn't indicate charge
remaining.
My OS is XP SP2 with ACPI bios.
When I open the Power Options of control panel and read the battery
data, it's mostly blank with the new battery which leads me to believe
that the bios detects that it's not an original battery and blocks
most of the data but not all.
If so, this seems to me as an illegitimate blocking to free trade but
that's not what worries me, I just want my gauge back.
Any helping ideas, please?
jss
Sponsored Links
"jss" <jsantossilva@hotmail.com> wrote in message
news:28224e36.0503111659.4ac4ed07@posting.google.com...
> Hi,
> over 2 years old.
> remaining.
I would suggest that you have a pattern battery that has omitted the
circuitry that reports the charge status to the Laptop.
Ian.
Reply to Anonymous
"Ye Electric Fanne Clubbe" <ian.shorrocks@baeherclothessystems.com> wrote in message news:<423584f0$1_1@baen1673807.greenlnk.net>...
Hi Ian,
Thank you for your help but I'm sorry to say that the battery has a
circuit similar to the original pack. I saw it. It has a
microcontroller and several glue IC's.
In fact, I tried to replace the new circuit with the original one on
an attempt to make it work. What happened then is that I ruined the
original circuit because stupidly I didn't notice that the new cells
were assembled reversed to the original and so I applied a reversed
voltage to the original (not new circuit).
Any other thoughts?
jss
Reply to Anonymous
jss wrote:
> Hi,
> over 2 years old.
> remaining.
> jss
This happens if the computer can't determine the charge level.
Sometimes the vendor supplies a calibration utility or manual
instructions to fix this.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
Reply to Mike
news:28224e36.0503211608.6b11fe61@posting.google.com...
> Hi Ian,
I cannot remember the content of the original post, but do I understand that
you have disconnected the circuit board from the batteries? Most of these
circuits have a small amount of processing power to manage the battery
charging: report the charge status etc, as you note. A number (but not all)
hold the processor program in RAM, either separate RAM or as part of the
microcontroller. These are programmed once the battery pack is assembled.
Diconnect the batteries from the board and the program is gone.
Having said that, the fact that you can charge the battery without it
errupting an a huge fireball suggests this scenario is unlikely. If the
cell conections to the new board are reversed to the original, then this
would indicate that the new board is different.
It may be that the replacement battery pack was just plain faulty, but as
you have pulled it apart, I suspect a warranty claim is out of the question.
Just a final thought. Have you tried calibrating the charge monitor
(assuming it exists)? This is achieved by fully charging the battery and
then allowing the laptop to discharge it until it shuts down. Many modern
laptops flag this event to the battery monitor circuit together with the
intended percentage charge endpoint. The monitor circuit stores this
information and then uses it to calculate the charge level during future
discharges and signal this to the laptop, At least that is the was it
should work.
Ian.
Reply to Anonymous
mike <spamme0@netscape.net> wrote in message news:<423F7F2F.6020906@netscape.net>...
> mike
Hi Mike,
Thank you for your help.
I just contacted the supplier, which is psaparts in the UK, and
unfortunately they weren't able to help. They just offered a refund in
case I want to turn it back.
jss
Reply to Anonymous
There are 1257 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
