Need help with USB power questions
I thought that, in addition to providing extra USB ports, externally powered USB hubs provided a "solution" to the system power supply/board not providing sufficient power to support multiple devices. Is this incorrect?
My situation (at the moment) is this:
I have a system with a 550W power supply, with 4 USB 2.0 ports off the back of the motherboard and 2 more USB
2.0 ports off the front.
I have an externally powered, 7 port USB 2.0 hub connected to one of the 4 rear ports;
I have a 2nd externally powered 7 port USB 2.0 hub connected to another of the 4 rear ports.
I have a Hewlett Packard multi-function printer/scanner/fax connected to the 3rd of the 4 rear ports.
The 4th rear port is empty
I have a wireless mouse "dongle" connected to one of the front ports
My problem (at the moment) is this:
Nothing connected to either of the external 7 ports hubs is being seen by the system.
By way of additional explanation:
All devices formerly (or normally) connected to either of the external hubs worked just fine ... until ... I added this
multifunction printer/scanner/fax to the system. At first, I added it to one of the external hubs ... and neither it, nor
any of the other things connected to either hub was seen ... including the mouse (very frustrating).
I rectified the mouse problem by 1) unplugging the printer from the hub I had put it on. Rebooted. Everything
returned to normal. (whew)
I then installed the printer into one of the 2 empty ports on the rear of the motherboard. Rebooted. Printer "seen" by
the system, no mouse (again, very frustrating)
I then installed the mouse "dongle" into one of the 2 front USB ports. Rebooted. Mouse is back (whew). Printer seen.
Two external hubs both show power (power light lit up), but no devices (a couple of memory sticks) were seen.
What I *think* is happening here is that the printer, even though it too is externally powered, is somehow taking too much USB power (is there even such a thing?) from the rear ports, effectively killing them. If the printer is connected to either of the HUBS, even though they are externally powered, it's not getting enough juice from them.
I'm confused, and can't explain it sufficiently to myself that I can come up with a solution.
Any help would be more than greatly appreciated, and will earn a (virtual) 6 pack of the drink of your choice ... unless you
happen to be Kevin the guy who lives next door, in which case the 6 pack WON'T be virtual.
Thanks.
Thanks.
