Case fans no longer turn on after installing motherboard
TheDynasty
4
I installed an ASUS Rampage III Formula motherboard today, as well as a new i7 CPU and new RAM. I am using the same PSU and GPU. I haven't yet closed my case or plugged my computer into my monitors yet, as my desk space is fairly constricted and it's a major pain to move my tower in and out.
I'm thinking there might be some sort of BIOS causing this, but my fans are only plugged into my Thermaltake Toughpower XT 775w.
Any ideas?
TheDynasty
4
I can't think that's the case, or it's pretty unlikely due to two factors.
First, I used these fans earlier this morning before I replaced the motherboard, and the wiring is chained so that the same 4pin connection goes from each fan to the next (the last fan in the chain is working).
I went ahead and plugged my computer into my monitors to see if I could figure something out in the BIOS. My motherboard is signaling a hardware error on startup, and says there's a problem with the CPU fan (I don't know if this is triggering the error code, or another issue). I'm a little confused by this because the CPU fans are visibly spinning.
Do you have any free connectors left on the PSU? if you do and if those Case fans can be separately connected to separate power connectors from the PSU, do it and check.
The CPU fan error must be because it may be spinning at speeds slower than the minimum, that can be rectified in the BIOS by setting a lower threshold limit or then if you're sure the CPU fan works fine, just disable the speed detection for the CPU fan.
TheDynasty
4
Ok, the CPU fan problem was a dumb error due to plugging my CPU fan into the OPT_FAN1 slot and my Case fan into the CPU fan slot.
Tried different combinations of plugging the fans into the PSU (it's a Thermaltake Toughpower XT so the PSU is modular. Side fan is still the only one that turns on. The BIOS doesn't detect any fans in the mobo besides the CPU fan (I have the 2, one in OPT_FAN1 and one in CHAS_FAN1.
The fans are pretty much http://www.thermaltakeusa.com/Product.aspx?C=1164&ID=1721. (Shouldn't need to be plugged into the CPU, except as an RPM monitor).
