So I'm building my new rig with the following specs:
Antec 1200 Case
i5 2500k
Asus P8P67 Pro
8 GB G.Skill RAM
GTX 570
I'm taking my hard drive and power supply from my old system and putting it into my new system. I finished up last night, and was getting a green light on the motherboard but the On button did nothing. So I took a look at the manual again and decided my Power Switch plug was in wrong. I rotated and that did the trick. It would do a double boot, but everything turned. However, I had no visuals. It was late so I had to go to bed and slept on it. I decided my problem was I only had one power supply cable plugged into the motherboard, the 24 pin. So when I got home today I plugged in the four pin on the opposite side, which I believe powers the CPU. Now my problem is the motherboard light is glowing green, but the power button does nothing. Any ideas?
Antec 1200 Case
i5 2500k
Asus P8P67 Pro
8 GB G.Skill RAM
GTX 570
