Hey,
My birthday just passed yesterday, and my friends got me a 150dollar giftcard to Microcenter, so instantly, two options popped into my mind.
Both options require me to add an additional 100 dollars which I'm willing to do..
First option I have is getting an SSD. I'm going to wait on this till 3rd gen comes out in mid-feb/early march (hopfully). I'll be getting a 120/128GB SSD, and that'll run me about 250 dollars... (estimating from the current prices)
The second option is a Water cooling system..
Right now my system on air is at 3.5GHz with a max temp of 84C under 100% load.. It's a perfectly fine and stable system at the moment. Water cooling would drop those temps by alot (From what I'm reading, anyone with first hand experience, please help me out. This will be my first WC'd system).
With WC I'll probably have to chip in an extra 50 or so..
Of course, with water cooling comes a whole new wave of research. So far I've looked up the components of a WC kit which costs 300 at Microcenter. Newegg doesn't have a kit, but all the parts inside are available. So far it's rated pretty well.
CPU block: http://www.newegg.com/Product/Product.aspx?Item=N82E16835108113&Tpk=Apogee%20XT
Radiator: http://www.newegg.com/Product/Product.aspx?Item=N82E16835108086&Tpk=MCR220
Pump: http://www.newegg.com/Product/Product.aspx?Item=N82E16835108082&Tpk=MCP655
MCRES-Micro Revision 2 reservoir (Not on Newegg, but other sites rate it well)
Mount: http://www.newegg.com/Product/Product.aspx?Item=N82E16835108084&Tpk=MCB120
And it comes with a SmartCoils 625 40 inch clear tube..
http://www.microcenter.com/single_product_results.phtml?product_id=0326142
Online price: 240.95 + 7%tax + ~$20~ shipping = ~$280~
Microcenter price: 299.99 + 3.5% tax = ~$310~
I can also buy parts seperatly from microcenter, but that would probably cost more..
~also, my case has a CPU-socket hole? so I can replace the HS/F pretty easily without taking the entire computer apart~
Thoughts?
My current system is brand new. i7-950, Sabertooth X58, OCZ Gold 6GB DDR3 1600, 850W Corsair modular PSU, GTX580, HAF 932 Black, Prolimatech Megahalems Rev.B.
Thoughts?
