Hello, I have a dell inspiron 1545 with windows 7 and i cannot connect to the networks around me
my wireless seems to recognize there are networks but when i click on one and try to connect, the box to type the network key in doesn't come up
please can you help
thanks
Hi, try to follow it.
hard wire to the router and verify you have internet
then
start - run - cmd
in the dos box type ipconfig /all
look for the default gateway
open internet explorer and type in the default gateway number from above (it goes right were you would type WWW.Google.com)
it should prompt you for a password. Most links are no username and admin as the password by default, or when it was setup. If this doesn't work you will need to reset the router (read as loose all settings and start over on your router)
if you do get logged in go to the wireless tab then security and write down your key or change it to something you will then know.
A remote possibility is to auto configure the links. This can be done if you have a links wireless card and a newer links modem - you'll have to look on links site for directions on that, I have never actually done it.
Good luck!
