Solved
Power question
Last response: in Systems
specs so far
Intel Core i7 920 Quad @4.1 ghz Zalman 9900 cooler
Asus rampage ii gene matx motherboard
18gb mushkin ram
Evga gtx 260 superclocked with extra %15 overclock
640gb seagate and 500 gb wd caviar green
Corsair tx650 watt PSU
do u think my power supply would handle adding one of these
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133376
itll be running 2 19" 1440x900 lcds
while my main card runs a 21" 1080p lcd and a 15" 1024x768
If not can anyone recommend a dual monitor card i could use
More about : power question
Related ressources
Homebuilt system Master
I believe you could do that. I think you'd be right at the top end of what that excellent PSU could do with your overclocks though.
I'd recommend you back off the overclocking while doing the install and testing at stock before you push the CPU up again.
Ask the community
