Every now and then when I'm gaming in World of Warcraft, typically when the fan speed would increase slightly in more graphic intense areas the fan speed will shoot to 100%. When this happens, programs like MSI Afterburner and EVGA precision read the fan speed as default(35% or so) and I can not manually change the fan speed.
I was going to let it go, but its extremely loud and I couldn't take it anymore and I also didnt want to kill the life span of the fan. At first I tried updating drivers, uninstalling any software that could maybe cause an issue such as MSI afterburner. None of this worked, so I decided to rip the card out of my PC, clean it out and Disconnect/reconnect the fan to the pcb on the card.
This somehow fixed the mysterious issue... Until now, just recently happened again. Pulled the card out re-seated and cleaned it out. Seemed to fix the issue.
Im curious what could be causing this to happen when it does. Im running this card in an old dell e521. Theres no screw holding the card in place its just some crappy black retention device. Could it possibly be vibration from the fan moving the card a little in the PCIe slot?
