I moved my computer (just built it 2 1/2 weeks ago and it works great) over to my TV (short distance) from my desk. I couldn't get something with HDMI scaling to work so I left it there for a few hours. Later I come back and find the computer off and the power cord unplugged (not sure how that happened). For some reason when I plugged it back in, flipped the power switch back and forth and turned it on, it was like it was never off. Everything was still open and I don't think Windows needed to reboot. Anyway, a while later I noticed a fan was rattling. It went away after a minute so I decided I'd check it out later.
A friend informed me it wasn't running a certain emulator well (very CPU intensive) so I looked at it and after checking the settings, started it up again and the screen just stayed black after initial launch. I shut it off (was busy) and later when I started it up again and I heard the same rattle, quickly killed the power and opened the case up. The top two plastic screw things on my CPU HSF were disconnected! No clue whatsoever how they popped out. I clicked them back in (hoping the CPU wasn't damaged from overheating) and after letting windows run through its unnecessary start up recovery thing (I forgot that's not just the check disc scan) and went into Windows (win 7 btw) and opened up Real Temp, I noticed the idle temp after sitting a number of minutes is averaging about 35-36C instead of my usual 31-32C.
I'm in a bit of a hurry and can't provide any more details this minute and I've left it turned off for now, but I'm worried about this whole event. Help please?
