G
Guest
Guest
I'm looking for a graphics card that will play all the latest game a t around medium settings and that wont cost me too much. Any suggestions?
My system is:
amd phenom 550 3.1ghz
2gb ddr2 ram
400w psu (can upgrade if needed)
15 inch monitor 1014 x 768 (getting new 1 soon)
budget is round $200NZD
I know that -- What I am trying to explain is that if for instance you buy the 5670 or 240 that you are thinking about now -- when you buy a new monitor that is larger (or now you mention EYEFINITY) then that card will not be powerful enough to run games at medium settings at those resolution (even 3 small monitors at 1280x1024 even would be 3840x1024 which requires some real graphics power to game at so you'll be stuck right back where you are today -- with a GPU that is too weak to game at the resolution of your monitor(s) ( the bigger your monitor the higher the resolution and the more powerful card needed to run things at a decent speed !! --- So best to decide what you are going to get eventually and buy a card today that will be able to run then instead of having to buy twice and waste the card you are currently getting !!I plan to get 1 after i get a graphics card.
