OK, Heres my Motherboard
GA-M68MT-S2 (Gigabyte)
MY CPU will be the FX 4100 QUAD CORE. It is on sale so I decided I should get it.
The board is AM3+ but on the Gigabyte website, it says if you want to use the FX processors, you must update your bios. How exactly do you do you update your bios? Can someone walk me through it?
http://www.gigabyte.com/products/product-page.aspx?pid=3967#ov
I don't wanna buy it, then i can't get it to work. Thanks everyone!
Heres build:
4GB DDR3 1333MHZ RAM
RADEON 6770 1GB DDR5
FX 4100 3.6GHZ CPU
250GB HDD
600W PSU MODULAR
GA-M68MT-S2 - GIGABYTE
Heres build:
FX 4100 3.6GHZ CPU
250GB HDD
600W PSU MODULAR
