I'm going to be building a new gaming rig in two months approximately.my budget is between 1000 and 1200$. These are the specs
1. AMD Athlon II X4 640 3.0 GHz
2. Gigabyte GA880GM-USB3
3. { G-Skill DDR3 1333 MHz RAM 8GB 4x2 Kit }
4. { Samsung SpinPoint F3 1TB }
5. Cooler Master HAF 922
6. ViewSonic 22" Full HD LCD Display
7. Microsoft Sidewinder X4
8. Roccat Kone [+]
9. LG H55N DVD R/RW SATA Optical Drive
10. Creative 2.1ch Speakers
11. XFX Radeon HD 6950 2GB
12. { 500-750 watt PSU }
(All components within Curly Brackets are those components where I need help)
I have to choose between
1. 8GB RAM and 1 HDD
2. 4GB RAM and 2 HDDs on RAID0
both of those combinations work out to a similar price.
I intend to go CrossFire, but only in 2-3 years. at which stage I intend to update my Mobo and CPU as well. If I can get a card that outperforms 2 6950s on CrossFire at a reasonable price at that future date then I will abandon CrossFire in favor of that GPU.
I really need help on that PSU. I have little experience with as I have always been content with whatever PSU came with my cabinet (Graphics Cards didn't exactly need separate Power Connectors back then). whatever PSU I get it has be within 40-50$. Preferably 750W (so I won't have to upgrade that if I were to go CrossFire). but if a decent 750W PSU isnt available at that price, a 500-600 or whatever wattage PSU is okay. It has to be or exceed 500W to support the 6950.
Thank You for your help and time
8. Roccat Kone [+]
