Solved
CyberPower Gaming Systems Monitor and Monitor cord
We have a cyber power gaming system. Can we connect that to a Dell monitor, and if so, what cord do we need to connect the monitor to the CPU?
4 answers Last reply Best Answer
More about cyberpower gaming systems monitor monitor cord
  1. Best answer
    You will likely need a DVI cable, chances are that the Dell monitor came with one. Look at the back of your system and you will be able to see what outputs the graphics card has, it will be either DVI or VGA and maybe an HDMI or DP depending on the card.
  2. The DVI cable should've come with the dell monitor but if you lost it you can buy just the cable: http://www.newegg.com/Product/Product.aspx?Item=N82E16812226011&cm_re=dvi_cable-_-12-226-011-_-Product
  3. Best answer selected by lizzy_322.
  4. Thanks, sorry it took so long to reply. Looked at the back of the system, and it was a DVI that could be purchased locally.
Cyberpower Gaming Connection Monitors Systems
