I have a few problems
when i go to support.ea.com/ it times out. And ive tried without firewall reset router settings i dont know what else to do. This is also I think the same reason I cannot play BFBC2.
8 answers Last reply
More about problems
  1. Is this only happening at the EA site.
  2. From cmd line can you ping support.ea.com?
  3. Yes I can ping the website.
    This is what i get
    Microsoft Windows [Version 6.1.7600]
    Copyright (c) 2009 Microsoft Corporation. All rights reserved.
    C:\Users\Kevo>ping support.ea.com
    Pinging ea.custhelp.com [216.136.229.95] with 32 bytes of data:
    Reply from 216.136.229.95: bytes=32 time=69ms TTL=243
    Reply from 216.136.229.95: bytes=32 time=65ms TTL=243
    Reply from 216.136.229.95: bytes=32 time=73ms TTL=243
    Reply from 216.136.229.95: bytes=32 time=71ms TTL=243
    Ping statistics for 216.136.229.95:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 65ms, Maximum = 73ms, Average = 69ms
    C:\Users\Kevo>
    And this is what i see
  4. Also to add on yes this is the only website from which i know times out.
  5. Anyone have any idea?
  6. Bump anyone? Help?
  7. I noticed you said you have a router. Have you tried a direct connection to the modem?
    Whats the brand of router and modem?
  8. NETGEAR wnr2000 motorola surfboard cable modem
Routers Support Firewalls Networking
