I am running 2 cards, an 8800 GT XXX from XFX and a 9800 GT from XFX. They are running in SLI and run great.
However the 8800's fan is a single speed 2 wire fan - 100% fan speed 100% of the time. I want to change out the cooling solution and figure I will do the same for the 9800 so they both match.
So, I need a GPU cooler that will fit both a 8800 GTand 9800 GT.
The 9800 GT is in the top PCI-e slot and I have 2 blank slots below that. There is a PCI and a PCIE slot between. Then comes the 8800 GT, but I only have 1 slot's worth of space below the 8800 GT, after that you run out of space and hit the motherboard.
So, what I ever I use most only take up 1 additional slot of space as well.
Ideas ?
Ideas ?
