So, I've recently put together this here build:
Mobo: ASUS M4A79T Deluxe
CPU: AMD Phenom II X6
RAM: (1) 4GB G-Skill Ripjaws 1333mHz
PSU: Rosewill Bronze 1000w
GPU: (CRAPPY!) Radeon 9250
Anyway, I had Windows 7 previously installed on a 200GB IDE HDD. I put it into the new case with all of the new stuff then booted. BIOS loads fine, Windows begins to start, gets about halfway through the Windows 7 animation, freezes, reboots, and then gives me the option for Windows Startup repair. Running Startup repair doesn't do anything. So I decided to do a fresh install of Windows 7. I plugged in an IDE DVD drive, put in the disc, set the boot priority to the drive, and I get the message to insert bootable media. Nothing will work, so I try a different drive, same thing happens. I test the drive in another computer and it reads the disc fine. Lastly, I try doing a External HDD USB install of Windows 7. I get the same exact message! Maybe I'm just doing something completely wrong. Should I format the External HDD and try that route? Does my mobo not like the IDE stuff? I've used a USB stick to update to the latest BIOS... I'm somewhat frustrated with this so any help is greatly appreciated!
