Solved
Cooler master extreme 460W vs CORSAIR CX430 - Which is better..???
Last response: in Components
May 5, 2011 7:43:02 AM
I would like to buy a graphic card for my PC, the GPU's that I have selected is either ATI HD5770 or NVIDIA GTS 450...
I know that Corsair CX430 or Cooler master extreme power plus 460w are good enough to run these cards...
Corsair = Rs.2500, Cooler master = Rs.2700
My Question is,
Which one of this PSU is better to buy to run these cards...??? I mean regarding quality, functionality, performance and brands
My budget is constrained, so tell me COOLER MASTER or CORSAIR and no new PSU pl z....
Unfortunately, FSP SAGA II 500W PSU that I selected is not available in nearby store...
Pl z help me with best answers... :D
May 5, 2011 9:09:25 AM
I'll need more information like the CPU you use, amount of hard drives etc..
But.. unless you have like 10 hard drives and an i7 990X I can't see why your computer wouldn't work with either of those power supplies.
m
l
a b ) Power supply
May 5, 2011 9:35:28 AM
Yes there both pretty decent power supplies.
m
l
May 5, 2011 9:56:08 AM
My system specs are...
Intel CORE 2 Duo E7200 @ 2.53Ghz
Main Board model: Intel DG31PR
HDD: 1TB Seagate + 160GB
Chip set: G33/G31 Express Chip set Family.
Transcend 4GB RAM DDR2 667Mhz
m
l
Best solution
a c 122 ) Power supply
a c 196 U Graphics card
May 5, 2011 3:31:15 PM
The Coolermaster is overrated. It isn't junk, but since it has a liar-label, it should be avoided on general principle: http://www.hardwaresecrets.com/article/Cooler-Master-eX...
The Corsair unit, otoh, is solid, so get that.
May 5, 2011 3:41:48 PM
so, Will Corsair CX430 gives enough power for HD5770..???
m
l
a b U Graphics card
May 5, 2011 4:06:07 PM
Yes, more than enough.
m
l
May 5, 2011 6:30:13 PM
Best answer selected by bairav.
m
l
May 6, 2011 12:04:17 AM
Thanks. Have fun with your new hardware.
m
l
