hi people....just wanted to no what system power i would need to run gtx470's in sli....i have a silverstone zeus 850 watt but not sure if that will be enough to cut it..
any suggestions ?
"GeForce GTX 470
On your average system the card requires you to have a 550 Watt power supply unit. We recommend at least 35 Amps in total available on the +12 volts rails (accumulated). A second card requires you to add another 250 Watts. You need a 850+ Watt power supply unit if you use it in a high-end system (1 KiloWatt recommended). That power supply needs to have (in total accumulated) at least 55 to 60 Amps available on the +12 volt rails."
"GeForce GTX 470
A modern, high-quality 850W psu would be enough to run 2x470. The issue is whether that Silverstone can deliver what it claims, and for how long.
I can't find a review of your specific unit, but the zeus 1200W was well received (other than taking a ding for low efficiency). A couple of Silverstone 850Ws have been "OK'd", but not all.
