Closed Solved
Multi-Monitors Problem
Hi guys,
I have a GIGABYTE GV-R435OC-512I Radeon HD 4350 graphics card with VGA+DVI+HDMI. When I try to connect three monitors to it only two of them could recieve signal. If I choose to use the last one, the connection to a former one will be forced disenabled. It happened to me in both Windows 7 display config and AMD Catalyst Control Center.
Do you guys have experiences on this? Is it a disanvantage of my video card or limit by the OS and software?
Your help is appreciated.
5 answers Last reply Best Answer
More about multi monitors problem
  1. Best answer
    Well im sure the HD4350 doesn't support eyefinity and to enable more than 2 screens you need to use ATI eyefinity or Nvidia surround technology.
    If you are simply just wanting more desktop space and don't do any gaming then i would pick up an HD5450 for a three screen setup.
    Check out this link http://www.newegg.com/Product/Product.aspx?Item=N82E16814150469&cm_re=5450-_-14-150-469-_-Product
    $49.99+ Free shipping and a life time warranty, This should fulfill your needs(as a non-gamer)
    OR
    Go for the HD6850/6870 If you are a Gamer, I have the XFX HD6850 from newegg and currently sold out.(Few more weeks till the 69xx release)
  2. ssshjp said:
    Hi guys,
    I think your card can only output to two monitors at a time; a common restriction.
    Just get a second cheap card.
  3. Thanks a lot for your advice.
    I am not a gamer. I choose low-end discrete card, not an integrated one, only for better multi-monitors output. That's too bad.
  4. Best answer selected by ssshjp.
  5. This topic has been closed by Maziar
Radeon Monitors Graphics Product
