Closed Solved
Comparision between (T6200 & DA5000pro) and between 2 sound cards
dear members ;
i have 3 questions and would like you to answer them for me ,
first question :
i have Creative sound system T6200 ( here)
and I'm willing to buy Edifier DA5000 PRO (here)
the question is : will it worth to upgrade from Creative to Edifier ?
Second Question :
i have Creative sound card > Sound Blaster X-Fi Xtreme Gamer (here)
and i'm willing to buy : Creative Soundblaster X-Fi Surround 5.1 Pro USB Audio System with THX SB1095 ( here )
the question is will it worth to upgrade from Xtreme gamer to Sound blaster Pro ?
- is the Creative Soundblaster X-Fi Surround 5.1 Pro USB Audio System with THX SB1095 is the best " EXTERNAL" Sound Card around 60$
Last question : If i bought the Edifier DA5000pro and connected to the " external" sound card ,will it work smoothly or there would be a Conflict ?
** is there any thing i should know before buying the " External" sound card and the Sound System ?
thanks for your time and for your help
6 answers Last reply Best Answer
More about comparision t6200 da5000pro sound cards
  1. Best answer
    1: never heard of those speakers or how they sound, won't comment on that.
    2: I think the card you have has better specs than the USB version.
    3: As long as you use the Analog outputs of your audio card (any card) it will work with the Edifier, as it uses 6 RCA inputs (no chance of drivers or software failing)
    1- ok
    2- the problem is that I don't have room for the " Internal" sound card when i upgrade
    so you are saying that if i bought the USB version it would be a Downgrade not an Upgrade ?
    3- thanks
    thank you
  3. 2 - The signal to noise, among other things is lower on the USB than the card you have. The difference will be there, but if you need external, you need external. I personally wouldn't care about the difference in quality between the two, but to answer your question, it its technically a downgrade.
    thanks for the explanation , you are a very helpful [:briovaz:2]
    thanks again
  5. Best answer selected by thetrue.
  6. This topic has been closed by Mousemonkey
Sound Cards Sound Blaster Creative Components
