First Build. Check out my system specs and give me pointers on build?
  • Homebuilt
  • Build
  • Systems
Last response: in Systems
February 7, 2011 11:54:20 PM
I've got two 7200rpm seagate sata drives already, so with these parts, I'm ready for my first build!
I'm a newbie, so I'm not super interested in over clocking my CPU or RAM, unless you all convince me my setup will remain the super stable at the increased performance (heat) levels allowed through over clocking.
Order Summary:
PSU:
XFX P1-650X-CAH9 650W ATX12V v2.2 / ESP12V v2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC Power ...
Item #: N82E16817207007
Standard Return Policy
$98.99
MB:
ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard
Item #: N82E16813131402
$88.99
RAM:
G.SKILL Ripjaws Series 4GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9S-4GBRL
Item #: N82E16820231310
Memory Standard Return Policy
$81.98
($40.99 ea)
Case:
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
Item #: N82E16811129042
Limited Replacement Only Return Policy
$59.95
Graphics card:
SAPPHIRE 100283-3L Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
Item #: N82E16814102873
VGA Standard Return Policy
$139.99
Processor:
AMD Athlon II X4 640 Propus 3.0GHz Socket AM3 95W Quad-Core Desktop Processor ADX640WFGMBOX
Item #: N82E16819103871
CPU Replacement Only Return Policy
$99.99
Subtotal $569.89
Tax $0.00
UPS 3 DAYS $5.81
Order Total $575.
I very much appreciate your advice on approaching my build.
More about : build check system specs give pointers build
February 8, 2011 12:03:07 AM
Hey there prad0597,
That's a very good build, and very similar to what I use currently. One thing I noticed is you put:
"G.SKILL Ripjaws Series 4GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9S-4GBRL
$81.98
($40.99 ea) "
Does this mean you are wanting 8Gb of ram? You probably do not need that much, and 4 GB in total usually does the trick for gaming and day to day use. So you might be better off (and save money) buy getting a (2 X 2GB) package of RAM instead. You also might want to consider a GTX 460 Graphics card (about $20 more) It would be worth the investment, and def. worth the price difference.
Hope this helps!
m
l
February 8, 2011 12:39:04 AM
bloodymoth said:
Hey there prad0597,
$81.98
($40.99 ea) "
Hope this helps!
Thanks for getting back to me. I bought this board thinking I may upgrade to a six core in the future, and at the same time kick up to 16gb RAM, maybe over the next year. I do some video editing as well, in adobe premiere, but I also game.
So, I want something good all around!
I'm hoping this will do the job.
As I envision the build, it seems that everything should be pretty intuitive. I'm scared to death I'll make some newbie mistake and fry a component or something, which is why I started out with a build that should be pretty simple. I don't have much experience, but I'm excited to learn.
m
l
