Realtek HD Audio digital in problem
Last response: in Components
Hello,
I have a Korg synth module plugged into the digital in on the rear panel of a Realtek HD Audio equipped HP computer. I am using a converter to change the stereo audio out of the synth module to a digital signal. The audio sys plays all of the on board sounds (dvd, cd, music programs, etc) but will not recognize or play the synth module sound. What am I doing wrong?
scoirvine said:
Hello,
Are you sure the port is digital INPUT,
and not by chance OUTPUT?
Yes. There are 2 jacks and I am using the digital out to my sound system which works just fine as long as all the sound sources are integrated into the PC (system sounds, CD, DVD, music programs, etc.) The Korg synth module is the only off board music source I am using. I updated the Realtek driver today and now I do get some soft static sound out of the module when I play it via my midi keyboard so it is inputting something but the PC audio is not doing the job like it should.
Ask the community
