I just finished building my new system using this motherboard
MB MSI|Z68A-GD65 (G3) Z68 LGA1155 R
Now i'm trying to install windows7 but it looks like i am having problems with my integrated graphics
I managed to boot on the install CD
It says "press any key to start the install CD"
then "Windows is loading files..."
When the loading bar is finished it says "Starting windows" and then my screen suddently lose all signal so i can't continue the installation
i'm currently connected through VGA. I also tryed to connect through DVI, i have the same problem except that the screen will constantly blink instead of just losing signal (during the "windows is loading files" part my screen will turn off and on constently, and when "starting windows" appears i will lose signal like with VGA)
I have a graphic card but i can't use it right now because my power supply is missing a 6-pin cable
I'm 100% sure that my Windows install CD is funtional, i installed windows7 many times including 1 time recently
