Help me build a gaming system under 500
Last response: in Systems
Gaming Expert
Azerothian
Fill out form in the sticky, link in my sig.
What country you're in for ex is helpful.
For a basic idea, here's a modified build from this thread I can do a better build with more details.
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E168... = $63
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E168... = $72
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E168... = $40 ($16 off as combo with mobo)
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E168... $176 AR
Hard Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E168... = $40
DVD Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E168... = $17
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E168... $40
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E168... $45
TOTAL: $493
Ask the community
