Right click problem
the previuos technician disabled the right click on any files on my pc..(desktop icons,folders etc.)
how can i fix this
3 answers Last reply
More about right click problem
  1. Have you tried another mouse to make sure the mouse you are using is not faulty?
    And what OS do you have?
  2. First create a restore point because you need to mess up with the registry. Go to Start/All Programs/Accessories/System Tools/System restore. Create a restore point. You can go back to where your PC was by selecting a previous restore point if needed (if something goes wrong)
    Then try this
    http://www.wikihow.com/Disable-Right-Click-in-Windows-XP
    To create the new value at point 5 click Edit then select REG_DWORD type.
    LE Late...
Desktop Icons Components
