Closed
Two different Timing/voltage RAM in the same system
Last response: in Memory
I have been running two pairs of different memory together for maybe 6 months, they are both 1gig Corsair XMS2 DDR2 800mhz except one pair has a voltage and timing of 5-5-5-18 1.80v and the other of 4-4-4-12 2.10v .
Despite the differences these four sticks worked happily together for the past 6 months, except yesterday either nvidia's motherboard update or window's 7 update decided to break this ignorant marriage.
Now the only way my system will boot up happily is with just one set installed, I have tried both combinations for having all 4 gigs in the system, with one the system gives out a long beeeeep and hangs, with the other the system hangs on the boot memory test.
and the mother board is a
Evga 750 SLi FTW
I was digging around the bios, and couldnt really see a way of setting the memory timings/voltages differently per ram slot.
...so My question is this, is there any way to get this to work? If I roll back and use the evga motherboard drivers (and not the nvidia ones) to get it to work (assuming thats what did it) am I hurting the system?
any help would be appreciated thanks!
Best solution
Memory Master
Motherboard Master
Welcome to Tom's Forum! :)
Well you at least get why we don't recommend mix-matching RAM ;)
Here's a mix to try:
DDR2-800 5-5-5-18 1.80v
DDR2-800 4-4-4-12 2.10v
DDR2-800 5-5-5-18 1.95v ~ 2.10v
1. Boot with only the working RAM
2. BIOS:
MEM (DDR), MHz -> 800
Memory Timing Setting /
Memory Timing Setting -> Expert
tCL (CAS Latency) -> 5
tRDC -> 5
tRP -> 5
tRAS -> 18
Command Per Clock (CDM) -> 2T
System Voltages /
Memory -> 1.95v ~ 2.10v ; trial by post/boot failure, you can start high and work down to 1.95v
Save & Exit = Yes
3. Shut down
4. Install all RAM
5. Boot and keep fingers crossed
Let me know.
Related ressources
Ask the community
