Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Chaintech > Gateway FX6801 power switch connection??
Forum Motherboards & Memory : Chaintech Gateway FX6801 power switch connection??
on the FX6801-01, can anyone tell me which 2 pins on the FP1 connector does the power switch connect to?
Reply to drdelp
http://www-etud.iro.umontreal.ca/~wardefar/notes/correct_pinouts.png
------------------------------ Where there's smoke, there's fire...
Reply to Nikorr
nikorr, thanks for replying to my post, I appreciate your time and input. My concern is that the Gateway FX6801 motherboard is propriatary, the FP1 connector has no labels, and from the factory, the only connector attached to it was the 2-wire power switch (all other front panel functions are fed from the USB connectors on the motherboard and go up to an enclosure at the front-top of the case.) UPDATE: I just took a chance, and jumped the 2nd set of pins (from the right), and it works; problem solved. Thanks very much, drdelp
Message edited by drdelp on 01-14-2012 at 06:22:36 AM
Reply to drdelp
im having the same issue i took out my motherboard to clean it on my gateway FX6801-03 and i cant find where to plug the 2 pin RED and white cable Power Switch connector onto the motherboard.. there is no label on my motherboard anywhere for it...... ughhhh i tried for like 5 hours to find it with no luck..[img]http://www.seeedstudio.com/blog/wp-content/uploads/2011/11/JST-2-pin-Power-Connetor.jpg
:cry: :cry: :cry: [/img]
Reply to fibercarbon
anyone please help!! i really need to find the spot on the motherboard for my gateway fx6801-03, to plug :whistle: the front power switch into.. i use my computer for work so i need help Urgently! any help is very much Appreciated
The 2-wire power connector attaches to the white header on the lower edge of the motherboard (about 1 inch from the lower right corner); It is attached to the 2nd pair of pins from the right of the header, closest to the edge of the MB; see image[img]http://i42.tinypic.com; hope this helps. drdelp
Reply to drdelp
Because that's the rules and if you don't like them then you shouldn't have agreed to abide by them, which you did when you signed up for an account.
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1554 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Memory for GIGABYTE GA-G41MT-S2P
By fantastik250, 8 hours ago:
Take a look at this and see if you like it. http://www.newegg.com/Product/Prod [...]...
Best offers
Top experts
