Core i5 stock CPU fan speed idle at 2500, maximum at 2700
is it normal to have a fan speed like that? :core i5 stock CPU fan speed idle at 2500, maximum at 2700"
4 answers Last reply
More about core stock speed idle 2500 maximum 2700
  1. No, but you should be able to adjust it.
  2. how to make it automatically adjust based on the cpu usage? so far it is quiet though. almost silent
  3. Well, it adjusts based on temperature, which it is doing, but there should be something in the CMOS setup/UEFI that lets you change that. May be under something like hardware monitor. Or a utility on the motherboard CD may do that too.
    But, if it is nearly silent, I wouldn't worry at all.
  4. is it a 3 pin or 4 pin fan. 3 pins can't be directly controlled through a motherboard header so they will run at they're max speed.
CPUs Core Intel i5 Fan Speed
