I'd like to get some input on this i7 950 I am looking at piecing together -- I have modified a workstation in the past by swapping out drives, graphics cards, RAM, etc but NEVER built one from scratch.
So, this is why I am looking at a "bare-bones" rig from eBay then adding the rest of the goodies. I guess for the last decade-ish our company has bought the system & Ive not had to do a complete build.
Assume I have nothing more than a monitor, keyboard, mouse & speakers...
SOMEDAY, I'd like to get a RAID-O setup and a Bluray on this, so wanna keep that in mind.
So... Here is what I have...
Parts Preferences: Compatible with i7 processor
Budget Range: under 2K
System Usage: 3DS Max, Syntheyes, After Effects (Adobe CS5 Suite)
Parts Not Needed: Monitor
Preferred Website(s) for Parts: New Egg
Country of Origin: USA
BAREBONES on eBay (FREE shipping) INCLUDES (for $969):
CPU: Intel Core i7 950 3.06GHz (Quad Core) 8000K
GPU: ASUS Rampage III GENE X58, DDR3, SLI & Cross Fire, SATA3, GB LAN, USB 3.0, iEEE
FAN: Coolmaster V6, 6 Copper Heat Pipes, Dual Cooler CPU fan
CASE: COOLER MASTER HAF-922 black, front USB & eSATA
PSU: CORSAIR 750W ultra quiet ATX Power Supply, SLI & X-Fire Ready
NETWORK CARD: (ONBOARD) NETWORK ADAPTOR (ETHERNET)
SOUND CARD: (ONBOARD) REALTEK HD DIGITAL AUDIO
THE rest (from NeEgg) (totalling $801)
MEMORY: ($179.99 + $6 SHIPPING)
CORSAIR XMS3 12GB (6 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model HX3X12G1600C9 G
Item#: N82E16820145235
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145235&cm_re=ram-_-20-145-235-_-Product
GRAPHICS CARD: ($234)
DIAMOND 5870PE51G Radeon HD 5870 (Cypress XT) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card w/ATI Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814103084
OS – Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM ($99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754&cm_re=windows_7_64-_-32-116-754-_-Product
HARDDRIVES:
Western Digital VelociRaptor WD3000HLFS 300GB 10000 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive ($169)
***Is this WD VelociRaptor something that would be beneficial if getting RAID setup in future with the WD drive below? Or should I simply get TWO of the same WD drive below now?
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136322&cm_re=Western_Digital_VelociRaptor_300GB_SATA_II_16MB-_-22-136-322-_-Product
Western Digital Caviar Black WDBAAZ0010HNC-NRSN 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive ($95)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136786
OPTICAL:
LG Black 22X DVD+R 8X DVD+RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD±RW SuperMulti Drive - OEM ($18)
***Will Add BluRay later)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136216&Tpk=GH22NS50
1)Thoughts on this? Is this a wise $1700 spent on a workstation for my purpose?
2)Are there any components that seem too llittle / too much /not compatible with this setup?
3)Am I missing anything ... other than total knowledge here?
4)Thank you VERY MUCH in advance!
I COULD still be saving about $150 or so if I built from scratch -- but honestly I am not sure I trust myself with some of these components.
HARDDRIVES:
OPTICAL:
