First homebuilt PC power problem ?
So my last PC was Dell Dimension 2400, and the replacement is the PC I'm assembling right now. I've installed everything except the graphics card (hasn't arrived yet), and when I turn it on, I hear 1 continuous beep continued by 3 short beeps, indicating that the VGA is missing (as expected).
The thing is, the moment I turn on the PC everything lights up for a second (fans, LEDS) then everything shuts down for a second or so and only then does it power on properly. This doesn't happen if I hold the power button just a fraction longer, in which case it powers up normally.
Is this normal ?
I can't find anything on this in the manual. Any help is appreciated.
Thanks.
PS. This is my first build so I'm still noobish. If there is anything more I should know please do tell.
1 answer Last reply
More about first homebuilt power problem
  1. Hello clarice;
    As you probably expected that's not normal behavior.
    I don't suppose you can borrow a video card till yours arrives?
    We can hope that adding a video card will fix that situation.
    What parts are you working with?
Homebuilt Power Systems
