Thinking about making a Gaming Rig with these parts. Opinions?
Processor:
AMD Athlon II X3 445 Rana 3.1GHz 3 x 512KB L2 Cache Socket AM3 95W Triple-Core Desktop Processor ADX445WFGMBOX
http://www.newegg.com/Product/Product.a ... -_-Product
Heatsink:
ZALMAN CNPS10X QUIET 120mm 2 Ball CPU Cooler
Motherboard
BIOSTAR A880GU3 AM3 AMD 880G HDMI USB 3.0 Micro ATX AMD Motherboard
RAM:
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX4GX3M2A1600C8
Hard Drives:
Seagate SV35.5 ST31000525SV 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s Internal Hard Drive
Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
CD/DVD Drive:
http://www.newegg.com/Product/Product.a ... 6827135204
Power Supply:
CORSAIR Builder Series CMPSU-500CX 500W ATX12V v2.3 Active PFC Power Supply
Video Card:
XFX GS-250X-YDFV GeForce GTS 250 512MB 256-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.a ... 6814150513
Case:
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
3 answers Last reply
More about thinking making gaming parts opinions
  1. Hello Trancedkuja;
    Your links are broken. If you can edit the links - just paste the link into the page without use the link tool.
    If you use the link tool - it wants an item description between the ] [/url brackets to make the like work right
    [cpp]ZALMAN CNPS10X QUIET 120mm 2 Ball CPU Cooler[/cpp]
  2. It honestly depends what games you are gonna play. I personally would stick with at least a 1 GB video card, but it all is a matter of WHAT you are gonna play. Games from mid 2007 and earlier should play on medium to high.
  3. How much are you going to spend on this build? If you're going for a budget build you should at least be getting a Pentium G3258 or an X4-860K. The Antec 900 is also a very outdated case, and you have a rather weak GPU.
New Build Systems Product
