Hey guys,
i currently built my computer but didnt attach all the connections for the controller as i wasnt quit sure, and i want to fix it up today.
im running a coolermaster cm storm scout and it has 3 fans (2 red clear ones,1 normal one) and a hyper 212+ cpu cooler. the motherboard is a asrock p67 extreme 4.
im wondering:
- with the fan cords (fan1, fan2, fan3 etc) they come with a 3 pin little connector and an bigger cored which i htink is 4 pin size but only 2 silver pins in it. do i only have to plug one of those in for each fan? and where do i plug it into? just into the power supply?
- also, where abouts do i stick the temp probes? and how do i know which fan is fan1, fan2 etc?
and then when all that is done, wht speed should i be running the fans at to make it quieter but still good temp?
im wondering:
