hello everybody,
I was just wondering that is an i7 2600k really a good processor, till now I don't have any discrete graphics card but in few days I will be getting a gtx 460 1gb. For now, I have a H67 motherboard, which means that I cannot overclock my i7 2600k. I presently run integrated intel hd 3000 graphics which is not a good performer I know, but when I ran FSX which is considered as a most CPU intensive game, I set most of the sliders to right and made my way to Seattle Tacoma Intl. airport (KSEA). I was shocked to see enormous amount of lags and frame rate dropped to 13 fps, I wondered that maybe its the problem of the graphics card, but I heard that even a low end graphics card paired with a high end CPU can max out fsx, therefore I have few questions to ask:
Is this a problem of my CPU or the graphics card?
Is overclocking an i7 2600k (fastest processor on the planet as per reviews) really worth?
If I will buy a gtx 460, then will fsx lag on the same settings?
after all, is an i7 2600k a good processor?
I was short on budget thus I bought ASUS P8H67-V but will later upgrade to a Z68 chipset.
thank you.
thank you.
