Hey all,
So I started having problems with my desktop about a week ago. While playing games, I started seeing lots of artifacts and glitchy video, and soon after the glitchiness started happening while not in games (while surfing, etc.).
I replaced the video card, but I'm still having problems: in Skyrim, shapes momentarily become pure blue or red; in Civilization V, after playing for an hour, the whole screen turned to video nonsense.
I tried running some diagnostic tools. I ran the older version of memtest that was included with my linux distro, and it turned up no errors in 1 pass. This was 2-3 days ago.
Today, I tried to run some of the UBCD cpu diagnostics, and all failed to load with kernel panics. I booted to Windows (XP) and ran prime95, but for some strange reason, it wouldn't run tests with the minimum fft size as 8mb, I had to set it to 10mb. I ran the combo test for 3 hours and it showed no errors or warnings.
I tried to boot back into the locally-installed memtest86, and the computer restarted after showing me the program for a split second. I'm now running memtest86 off of the UBCD with no problems, I'm going to leave it overnight, but it's run 2 passes and is showing no errors.
Any ideas, or thoughts on how I could further diagnose to find the problematic part? I'm thinking it's either the PSU, which probably killed the old video card and is causing the memtest restarts; or it's the cpu or motherboard, but the prime95 tests passed fine once I raised the
My setup right now is: MSI 975x powerup edition motherboard; intel e6400 core2 duo cpu; 4gb ddr2-800; evga gtx550 ti video 1gb video card; 2 sata disks.
Thanks in advance.
Thanks in advance.
