Yes No
Ads
Tom's Hardware > Forum > CPU & Components > CPUs > I7 950 blank no signal screen, no post code beeps help
Forum CPU & Components : CPUs I7 950 blank no signal screen, no post code beeps help
THERE IS NO POST CODE BEEP AND NO BIOS screen
MY friend has an I7 950 with ASUS P6X58D-E MB so he has been using it for few months now. After installing BitDefender Total Security 2011. He was asked to restart the computer and after restarting his computer won't POST. His Samsung TV screen just says "No Signal" he tried to reassemble the PC parts but still nothing works he replaced the PSU and GPU,switched the RAM and resesetted the BIOS even replaced the CMOS battery, checked for bent pin but still "NO Signal"
He suspects its the cpu because the cpu fan spins and the gt 430 graphic card only draws power from the mobo but the gpu's fan DOES spin
Reply to ralphguy298
By "won't post" you mean you can't get into the BIOS? Or it won't start Windows? If it won't start Windows, a reinstall may do it. If it won't even get to the BIOS, something "fried." I had something similar where the BIOS needed to be upgraded, but you have to get to the Boot up screen.
In another case I bought a cheap replacement CPU to get things going (BIOS flash).
------------------------------ Why can't men be groupies? Actresses need love too!
BaronMatrix
Reply to BaronMatrix
so you cant enter the bios?
So have you tried using another monitor?
Reply to ghnader hsmithot
OK this is now me the one who owns the i7, my friend let me use it for now
I tried using a different monitor too and no I cant enter bios, nothing, I cant get a cheap CPU replacement because the cheapest is another 950
Message edited by ralphguy298 on 05-17-2011 at 03:04:51 AM
I dont know how something could possibly be friend because everything was OK until that dreaded restart
There are 1507 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help Understaing Hardware Montior readings
By DJDeCiBeL, 2 hours ago:
 I agree with that assessment, and with the temps in that range, it's nothing to...
Best offers
Top experts
