Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Other Components > Wireless PCI card prevents POST
Forum CPU & Components : Other Components Wireless PCI card prevents POST
Hello,
I have a working wireless PCI card (linksys WMP600N) that I try to use with a desktop computer. Of course, I'm here because that doesn't work.
The problem is that the concerned PC doesn't get to the POST. The fans spins and lights goes on, no video and no beebs. (It still boots up without the PCI card, and the card still work in another PC).
Linksys support did no good. They however pointed that maybe it was a IRQ issue.
Can someone help me ?
Thanks
Reply to dalex_dragoon
if its an irq issue try it in another socket if you have 1 free. then again they are quite rare.
------------------------------ |i7 920 D0@3.6 |CNPS10 flex |ex58-ud5 |6Gig 1333 C7 |HD 5870
|G11 keyboard|X-fi Xtreme |G930 |3x1tb SpinPoint f3's raid 0 |thermaltake tp 850watt |antec 902
|Rat 7 contagion |Razer Destructor mat |bamboo pen'N'touch | 3d pro stick |nitro wheel |360 pad
Reply to HEXiT
I've tried the 3 PCI ports. No chance, no change.
Could still be IRQ problems, but that shouldn't prevent a POST. Doubt its power related, but its possible. And if no other devices are on the PCI bus, then its not a bandwith issue...
Reply to gamerk316
How could I solve the IRQ problem, considering it's the problem ?
have you overclocked your pc? if so it could be due to the pcie port speed?
Reply to robin banks uk
I did not overclock the PC. It's using the regular PCI port, not the express.
I don't even know where to change that from the BIOS, it doesn't give the option I think.
Just to let you know.
I've been able to install a PCI TV-Tuner card and a PCI Line in (phone cable) and the computer still boot. The problem seems to appear only with the wireless card.
Yet again, the wireless card still work in another pc.
Gosh... That card is a b_tch.
Sooo.... I've manage to get a old wireless g card from a good friend so that I could try it in the pc. It worked like a charm!
Is my card incompatible with the pc or is the pc incompatible with the card ?
Anyway, I'm still interested if you have an idea of what is causing the troubles.
I've had wireless cards prevent the pc from posting in a couple of older pc's but they were all class N cards. Drop in a b/g card and see if that works.
Reply to popatim
Yeah, a b/g card work when my n one is not.
Is this the only solution: to replace the card for a b/g one ?
I'm having a similar issue. I have a PCI-E adapter and a airport pci-e card that I put in my computer, it causes a continuous boot/reboot. The lights will turn on, beep once, HDDs spin... 2 seconds in, it will reboot and start the process over, never posts.
I can take the card out and it will boot up fine.
Message edited by millsj2 on 07-12-2011 at 04:32:55 PM
Reply to millsj2
There are 1544 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help Understaing Hardware Montior readings
By DJDeCiBeL, 2 hours ago:
 I agree with that assessment, and with the temps in that range, it's nothing to...
Best offers
Top experts
