Case fans and not enough mobo connectors
Hi,
I'm building my first pc without any prior knowledge on computers at all..
I got a case with a 2 pre-installed case fans and am trying to connect these to the motherboard. The problem here is that there is only 1 connector on my mobo which is 4-pin. Both of my case fans have 3-pin's.. What should I do? I looked online for a splitter that converts the 4 pin connector to 2 3-pin connectors but I can't find any. Please help!
9 answers Last reply
More about case fans mobo connectors
  1. My case fans are connected to the power supply using the Molex connectors that we used to use for disk drives.
    If your motherboard only has one fan connector then it is for the cpu cooler fan. My motherboard had more than one connector but I went with the power supply connectors anyway just to reduce the load on the motherboard slightly.
  2. Yep! like cadder i've always connected my case fans to the molex connectors which you can chain together btw= multiple fans on one connection
  3. thank you for the reply!
    sorry if I sound extremely dumb, but do they sell molex to 2 3-pin splits? And if so, just connect that directly to the power supply im guessing?
    Yep! you just use the psu's molex connectors for case fans.
    Do your case fans not have molex leads?
    I'm not quite sure what you need.
    http://www.frozencpu.com/cat/l2/g2/c251/list/p1/Cables-Fan_Cables.html
  5. Here is a splitter for you:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16812189063&cm_re=3_pin_y_cable-_-12-189-063-_-Product
    They can be found on ebay for a little cheaper.
  6. I ordered 2 things: 1 cable that went from 4-pin to molex and another from molex to 2 3-pin
    I think that should do, but in the case that it doesn't I guess I'll just get a fan controller?
  7. what case have you got there?
    post a couple of pics if you dont know the model, but you should be able to connect the fans straight to your psu, as mentioned
    Moto
    Moto
    The manual reads: Vortex 36XX Series and this one's apparently the Maxcube 36xx
    The mobo that I have is the GIGABYTE GA-H67M-D2-B3 LGA 1155 Intel H67 SATA 6Gb/s Micro ATX Intel Motherboard
    sadly it only has 2 fan connectors, one for the CPU and one for the system. :( why can't there be a few more? I'm heavily dissapointed
  9. check your psu it may have 3 pin connectors so you can attach them directly to it rather than the motherboard. if it doesnt then you can but 3 pin to 4pin molex like other may have said. there about a £1/$1 each.
Power Supplies Cases Computers Components Product
