Just completed a brand new build 1o minutes ago.
Upon start up my power supply is making a fairly loud noise it sounds like the fan hitting something. Visually I cant see it happening, I restarted it a few times, nothing changes. The machine seems to be running fine and its currently installing windows.
The power supply is the PC power and cooling 750 W Silencer MK II.
Should I turn the machine off and return the power supply? Should I just let it run?
Other Components:
MOTHERBOARD Gigabyte p67A-UD4-B3
CPU INTEL 2500k
GPU MSI 560Ti
RAM 8GB Corsair Vengeance
CASE CM 690 II Advanced
HD Caviar Black 1TB
I'd really appreciate any help, and if I posted this in the wrong place please let me, I'm a newbie to the forums
Other Components:
CPU INTEL 2500k
GPU MSI 560Ti
HD Caviar Black 1TB
