Solved
First Post, First Build, Help with Mobo and Monitor
Last response: in Systems
February 16, 2011 1:19:05 AM
I am building a new computer and I have been gleaning information from the forum. Thank you, all you experts, who chime in with your wisdom.
Approximate Purchase Date: tomorrow or the next day
Budget Range: less than $1000 including the monitor
System Usage from Most to Least Important: Games like SC2, Crysis, Web Surfing
Parts Not Required: Keyboard, Mouse, Speakers
Preferred Website(s) for Parts: micro center, frys, newegg, amazon
Country of Origin: Orange County, CA, USA
Parts Preferences: AMD
Overclocking: Yes
SLI or Crossfire: No
Monitor Resolution: upgrade to 1080p FIRST QUESTION: What size/brand/response time monitor do you think is best?
I currently have a Samsung SyncMaster 930B
# Max Resolution 1280 x 1024 / 75.0 Hz
# Max Sync Rate (V x H) 75.0 Hz x 81.0 KHz
# Video Bandwidth 140.0 MHz
# Response Time 8.0 ms
Additional Comments: I am going to put a Phenom X4 965 inside. SECOND QUESTION: I am stuck on mobo's. Is there really much of a difference in quality? With the Microcenter bundle any mobo is $40 off with a cpu so what do you recommend? Gigabyte GA-880GM-UD2H Socket AM3 880G mATX? Asus M4A87TD/USB3? Gigabyte GA-880GM-UD2H?
THIRD QUESTION: Should I return the 5770 and get a better GPU like a GTX 470 or HD 5870?
This is what i received from newegg today, please give me your input on the right mobo that is compatible with the ssd and memory. THANK YOU! -Deanomite
NZXT M59 - 001BK Black Steel ATX Mid Tower Computer Case $59.99
Item #: N82E16811146058
OCZ StealthXstream II OCZ600SXS2 600W ATX12V v2.2/ EPS12V 80 PLUS Certified Power Supply $73.99
Item #: N82E16817341039
DISCOUNT FOR COMBO #596048
-$35.00
LG DVD Burner - Bulk Black SATA Model GH24NS50 - OEM $16.99
Item #: N82E16827136177
Crucial Ballistix 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model BL2KIT25664BN1337 $39.99
Item #: N82E16820148323
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM $99.99
Item #: N82E16832116754
SAPPHIRE Vapor-X 100283VX-2L Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support ... $129.99
Item #: N82E16814102898
OCZ Vertex 2 OCZSSD3-2VTX120G 3.5" 120GB SATA II MLC Internal Solid State Drive (SSD)
Item #: N82E16820227590 $206.99
subtotal before rebates: $638
February 16, 2011 5:18:13 AM
1080p and Crysis on the table for me HD 5770 way too GPU lite and since u state Microcenter as an option:
965BE + MSI 870A-G54 $190
http://www.microcenter.com/specials/promotions/AMDbundl...
Most 870 chipsets are either single or 16/4 so hitting a single GPU set up
Items Off Egg
$532AR
23.6 LCD $150 Free Ship
$872AR core build
Optional Items
CM 212+ Hyper cooler $30
60GB Sandforce based SSD $105AR Free Ship
Edit
The NZXT M59 + OCZSII 600 combo as well as Crucial Bal 2 x 2 deals in your proposed config are gone/sold out
February 16, 2011 5:25:22 AM
batuchka, I am glad you helped me out. I've seen you post a lot and you sure can find those deals!
February 16, 2011 5:28:41 AM
I already bought:
-$35.00
and need to return the GPU to get the 560ti you recommend.
I also think the large ssd is overkill but I am going to keep it.
I will goto microcenter tomorrow or the next day to get the CPU/mobo
February 16, 2011 5:28:51 AM
Haha yep u are welcomed ^^
February 16, 2011 5:32:55 AM
I am stuck on mobo's. Is there really much of a difference in quality? With the Microcenter bundle any mobo is $40 off with a cpu (not just the ones listed on the bundle page) so what do you recommend? Gigabyte GA-880GM-UD2H Socket AM3 880G mATX? Asus M4A87TD/USB3? Gigabyte GA-880GM-UD2H? or the MSI 870A-G54 like you said?
Best solution
February 16, 2011 5:34:47 AM
Had built plenty with that MSI 870 hence i would say it's a good choice but the Giga 880G is actually my fav combo for SFFs, mATX builds but for an ATX mid tower build and going discrete it's not as desireable hehe
February 16, 2011 5:38:20 AM
Cool, thanks, I will go with the MSI 870A.
I plan on overclocking to 3.8 is the CM 212+ Hyper cooler $30 necessary or is the stock cooler sufficient?
February 16, 2011 5:42:46 AM
I could put a third fan in the case, would that help out?
February 16, 2011 5:43:27 AM
Whoa for 955BE peeps have reported 3.5-3.6 on stock but then again that depends on their ambient so for higher clocks/best results hit an after market
February 16, 2011 5:45:24 AM
We're looking at a 965BE, so 3.8 is reasonable for that right?
February 16, 2011 5:47:38 AM
but I guess the point is, if I overclock I should have the CM 212+ Hyper cooler, so I will get one.
February 16, 2011 5:48:21 AM
Well for OC YMMV so can't say for sure on stock HSF but you could try it out and see if how your chip responds clocks/temps ^^
February 16, 2011 5:55:53 AM
that makes a lot of sense. One can always try it and see how it goes then get a cooler later if it getting too hot. If it were you, how much would you overclock a 965BE?
February 16, 2011 5:56:34 AM
I am asking because I haven't OC'd yet and am learning about it by reading different forums, and you have experience with it.
February 16, 2011 5:58:11 AM
In that case no rush and you could pick it up - many subforums for OCing online so good luck ^^
February 16, 2011 5:59:26 AM
cool. Ok, thanks for your help! You're a star!
February 16, 2011 6:00:29 AM
Best answer selected by deanomite.
February 16, 2011 6:04:34 AM
Yep happy shopping/building and cheers ^^
February 16, 2011 6:09:09 AM
I thought of another question, if you don't mind: on the Western Digital Caviar Blue WD5000AAKS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive What does it mean that it is a Bare Drive? Does it need a mounting bracket or something?
February 16, 2011 6:11:01 AM
Nah all/most casings have a 3.5" bay so it's all good ^^
February 16, 2011 6:15:20 AM
ok, cool, i saw "bare" and figured it was missing something!
