Solved
2nd Post, 1st Build - <> - Need Help with Crossfire Mobo & Monitor
Thanks in advance for helping me with two more questions; I welcome anyone's input:
Approximate Purchase Date: today or tomorrow
Budget Range: less than $1000 including the monitor(s)
System Usage from Most to Least Important: Games like SC2, Crysis, Web Surfing
Parts Not Required: Keyboard, Mouse, Speakers
Preferred Website(s) for Parts: micro center, frys, newegg
Country of Origin: Orange County, CA, USA
Parts Preferences: AMD
Overclocking: Yes
SLI or Crossfire: YES
FIRST QUESTION: I decided to keep the 5770 I bought a couple days ago and will get a second one to crossfire instead of returning it for a single better card; WHICH MOBO SHOULD I ORDER FROM MICROCENTER WHEN I PICK UP A PHENOM 965BE? (With the CPU bundle they give $40 any mobo in the store).
Monitor Resolution: upgrade to 1080p?
SECOND QUESTION: Would it make sense to keep my current monitor and go to a multi-screen scenario?
I currently have a Samsung SyncMaster 930B
# Max Resolution 1280 x 1024 / 75.0 Hz
# Max Sync Rate (V x H) 75.0 Hz x 81.0 KHz
# Video Bandwidth 140.0 MHz
# Response Time 8.0 ms
Additional Comments:
I have already bought and received the following components from newegg, please give me your input on the right mobo that is compatible with the 2 GPUs, ssd and memory. THANK YOU! -Deanomite
NZXT M59 - 001BK Black Steel ATX Mid Tower Computer Case $59.99
Item #: N82E16811146058
OCZ StealthXstream II OCZ600SXS2 600W ATX12V v2.2/ EPS12V 80 PLUS Certified Power Supply $73.99
Item #: N82E16817341039
DISCOUNT FOR COMBO #596048
-$35.00
LG DVD Burner - Bulk Black SATA Model GH24NS50 - OEM $16.99
Item #: N82E16827136177
Crucial Ballistix 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model BL2KIT25664BN1337 $39.99
Item #: N82E16820148323
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM $99.99
Item #: N82E16832116754
SAPPHIRE Vapor-X 100283VX-2L Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support ... $129.99
Item #: N82E16814102898
OCZ Vertex 2 OCZSSD3-2VTX120G 3.5" 120GB SATA II MLC Internal Solid State Drive (SSD)
Item #: N82E16820227590 $206.99
subtotal before rebates: $638
9 answers Last reply Best Answer
More about post build crossfire mobo monitor
  1. I think I just figured out the mobo question: Batuchka recommended the MSI 870A-G54
    I looked up the specifications and it says # PCI-Ex16 = 2 so that means it can hold two gpu's right?
  2. Nope a mobo can have 2 x PCIex16 gen 2.0 lanes. What is important is how it is configured when 2 GPUs/multi GPU is working : 870 chipsets with 2 lanes works 16/4 so are not recommended for multi GPU
  3. ok, thanks, which chipset number(s) have 16/16? Then I can look up mobos later when microcenter's supply truck restocks their boards.
  4. Best answer
    On PCIex16 gen 2.0 lanes 8/8 is fine so on AM3 chipstes look for
    790X
    790GX
    890X
    890GX
    Asrock 870/880G Extreme3 models
  5. Awesome! Thanks Batuchka! You Rock!
  6. It looks like I could get
    GA-890XA-UD3 Socket AM3 790X ATX Motherboard for $107
    GA-890GPA-UD3H AM3 890GX ATX AMD Motherboard for $83
    or
    890GXM-G65 Socket AM3 890GX mATX AMD Motherboard for $72
  7. Yep u are welcomed and cheers ^^
  8. Best answer selected by deanomite.
  9. cool, i will go with GA-890GPA-UD3H AM3 890GX ATX AMD Motherboard
New Build Systems
