New build wont boot!! help
Last response: in CPUs
May 18, 2011 7:21:03 PM
This is my first build, when i turn on the power, evrything works except the the led dr.buger on the motherboard.
There is also no video output.
This is my spec
Mobo : Asrock P67 Extreme4
cpu : i5 2400 sandy bridge
ram : 2x2gb g.skill ripjaws x series F#-12800CL8D-4GBXM
psu : antech 750 watt 80 plus
hdd : samsung f3 spinpoint
gpu : msi nvidia gtx460 1gb hawk talon attack
Everything will run except the led dr.buger on motherboard and there was no video output
More about : build wont boot
a b à CPUs
May 18, 2011 7:25:03 PM
Hello!
How are you and Welcome to THG!
I dont understand.What is Buger on the motherboard?
m
l
May 18, 2011 7:32:27 PM
This is my spec
Either your motherboard is bad or the video is bad.
First step is to unplug everything and firmly plug back in. RAM especially will cause stuff like that if its not seated properly. Does ASRock have an FAQ that tells what the lights mean? Check their site for compatibility of the RAM also.
m
l
May 18, 2011 7:44:52 PM
i had checked the ram compability at asrock website and my ram is not compatible with my motherboard T_T
Is there any possibilities other than ram.
m
l
May 18, 2011 7:47:24 PM
ghnader hsmithot said:
Hello!
Led number on motherboard that should turn on when the cpu is running
m
l
a b à CPUs
May 18, 2011 7:49:30 PM
What??
I checked and your ram and mobo is compatible.
m
l
May 18, 2011 8:05:06 PM
Was the ram specifically listed as not compatible or just not listed as compatible? Also, what PCI slot is the VC in? Ussually the VC won't work unless in the fist compatible slot. Do you hAve another VC you can toss in there to rule that out also?
m
l
a b à CPUs
May 18, 2011 8:27:14 PM
Did you plug in the 24pin, and 4/8pin power from PSU to the motherboard. Sounds like you maybe missing the 4/8pin.
m
l
May 18, 2011 8:28:55 PM
vc on the 1st slot, no other vc to try with.
my ram not listed as compatible
m
l
May 18, 2011 8:29:41 PM
everything went to the correct port, no miss cable or what so ever, the jumper also fine.
m
l
May 18, 2011 8:36:35 PM
Led number?The case lights?
not the case light, if you look at the motherboard there is a led number that called dr.buger i think.
my friend also has the same mobo, and he said if the cpu pin not connected the led will not turn on
m
l
a b à CPUs
May 19, 2011 1:54:39 AM
i will check the manual on the mobo site later.
m
l
May 19, 2011 7:45:17 PM
anyone can help me pls
m
l
May 19, 2011 11:22:58 PM
Like I said, RAM can cause this. If they EXPLICITLY say your RAM is supported that's 99% your problem. Of course it could be a combination of things. Can you pick up some cheap sticks that are supported? If that's the problem you can take the temps back and perhaps exchange the originals.
Where did you buy the parts?
m
l
May 21, 2011 2:41:46 PM
I did not say the ram is not compatible, just the ram is not in the compatible list. I tried breadboarding but nothing happened, there was no beep whatsoever and the dr.buger led also didnt light on. I guess it might be the mobo that faulty
m
l
a b à CPUs
May 21, 2011 4:14:50 PM
Is this your ram?
Quote:
Qualified Motherboards List
ASUS P8Z68-V PRO
ASUS Maximus IV Extreme
ASUS SABERTOOTH P67
ASUS P8P67 DELUXE
ASUS P8P67 EVO
ASUS P8P67 PRO
ASUS P8P67-M PRO
ASUS P8P67-M
ASUS P8P67 LE
ASUS P8P67
Gigabyte GA-Z68X-UD7-B3
Gigabyte GA-P67A-UD7
Gigabyte GA-P67A-UD5
Gigabyte GA-P67A-UD4
Gigabyte GA-P67A-UD3P
Gigabyte GA-P67A-UD3R
MSI P67-GD65 (Bios Ver 1.B)
MSI P67-GD55 (Bios Ver 1.B)
MSI P67-GD53 (Bios Ver 1.B)
ASRock Fatal1ty P67 Professional
ASRock P67 Extreme 6
ASRock P67 Extreme 4
Biostar TP67XE
http://www.gskill.com/products.php?index=350
m
l
a b à CPUs
May 21, 2011 4:24:07 PM
Are you saying of Dr Debug?
Dr Debug is used to read of error codes.So are you saying no error codes are flashed?
And could you try a dvi to vga adapter?Please try one of these adapters.
m
l
